Hello. My friend has an old Pontiac Firebird that has been leaking oil for a while. I changed his oil recently and when I went to replace the drain plug after draining, the plug did not tighten or get snug. The thread on oil drain plug itself is not stripped. So, I assume that the thread inside the oil pan is. Without replacing the entire oil pan, is there anything I can do to get the oil drain plug to tighten in the oil pan? Thank you.
Sep 12, 2009 at 4:58 PM
