1999 Pontiac Firebird Smells Like Gas
1999 PONTIAC FIREBIRD
CBRUTON43
Smells problem
1999 Pontiac Firebird 6 cyl Two Wheel Drive Manual
My car has a strong oder of fuel inside the car and is very strong.. Would could cause that smell?
Jun 19, 2009 at 7:55 AM
SYSTEMAT1C
sounds like your car is running to rich, wipe you finger accross the end of the inside of the tailpipe and if there is black residue, your most likely running to rich, if you are, replace your oxygen sensors. and if thats not the problem, you have a gas leak somewhere, check the fuel lines going into the engine for any holes or cracks, good luck!
Aug 31, 2009 at 12:47 PM
