1999 Pontiac Firebird power locks
1999 PONTIAC FIREBIRD
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
URLACHER
I have a 99 Firebird. The drivers side power lock will lock both doors, but will not unlock them. The passenger side works fine, and both sides work fine manually. I bought a new switch, this was not the problem. I think the next step would be the actuator. But thought I would check this time before I buy. Thanks.
Jul 26, 2010 at 8:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
if they will lock the doors but not unlock them then it is either a failed switch or failed lock actuator. since you replaced switch already it must be actuator needing replaced.
Jul 26, 2010 at 8:30 PM
