1999 Pontiac Firebird 1999 Pontiac Firebird - No Coolant in
1999 PONTIAC FIREBIRD
65,985 MILES • 6 CYL • 2WD • AUTOMATIC
TESTENGINEER
I have a 1999 Pontiac Firebird 6 cylinder. I checked the coolant a few days ago and it was empty. The Coolant reservoir was empty also. There are no obvious leaks. The car is not getting hot or anything else that I notice.
The only thing I did notice was when I removed the cap type dipstick from the reservoir, it looked like it had some brown crud coverig the stick about 1/4 of the way up with no water dripping off of it.
Thank you,
Aug 20, 2009 at 4:16 AM
Joe:
I recommend cleaning that out and refilling the system. If there is a leak, with the system full you should see it. Also, check the passanger side floor for coolant from a bad heater core.
Let me know what you find.
Sep 9, 2009 at 10:19 AM
