1998 Pontiac Firebird Turning Signals
1998 PONTIAC FIREBIRD
102,000 MILES • 6 CYL • 2WD • MANUAL
SCRABSTAR
My turning signal bulbs are lit, but they stopped blinking in the dash display and outside the car in both directions.
I checked the fuse, in the main fuse box by the drivers side door, and it looked ok to me. What else could the problem be? Is there a relay or something that could have failed?
Jan 8, 2010 at 8:58 PM
Check and test the turn signal flasher and the turn and hazard switch
Jan 8, 2010 at 9:00 PM
SCRABSTAR
Ok, so the Hazard lights still work, I switched the fuse from the Hazard spot to the Turning signal spot and still nothing. Any ideas?
Jan 8, 2010 at 9:13 PM
Test the turn and hazard switch everything goes thru there then to the back lights
Jan 8, 2010 at 11:48 PM
SCRABSTAR
You mean the actual turn lever attached to the steering column, I'm assuming. What is the best way to test it? Do I need to take the wheel off to do this?
Jan 10, 2010 at 3:24 PM
Did you check the turn signal flasher? If okay you need to remove the s/wheel and trace the wires the turn signal wires Left sig is the light blue wire, Right sig is the dark blue wire-
Jan 10, 2010 at 4:06 PM
