I have a 97 firebird that is got so that there was no park when you would put the car in park it was really reverse and reverse and N were both N then any of the other gears worked as they should then one day the car got stuck in drive i played with it for a sec and the car went into reverse the car has been stuck in reverse for 2 days now i took the center console apart and everything looks as it should and goes back and forth like its putting it in gear everything from the floor up seems to be working fine im wondering if someone on here can tell me when they think or what i should try or any information on how the linkage of the car works also if it helps the trans. was rebuilt about 40k ago and shows no sign of slipping or hard shifting thank you any help would be a great help
Mar 4, 2009 at 11:48 AM
