1996 Pontiac Firebird no spark
1996 PONTIAC FIREBIRD
125,000 MILES • V8 • 2WD • AUTOMATIC
AVIA50347
i was driving and stop at the store. Left the car running for 1 min ran in side. Came out the car was not running. went to start car it wood not start . check fuel pump. had it towed home .check all fueses all ok .went to start car it started. it ran grate for two days . went to put gas in. after putting gas in tryed to start car wood not start . i found that it does not giting a spark .i check coil put new one on still same . just dont no why . plese help
Sep 9, 2010 at 11:58 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sep 10, 2010 at 12:02 AM
AVIA50347
I will chack that all Thank You.
Sep 10, 2010 at 12:09 AM
