Hello, if the vehicle cranks good but won't start, have a helper crank it, while you check for spark at the plugs and injector pulse. If you have both, use a gage and check fuel pressure.
There should be a fuel pump prime connector, behind the battery, gray wire with connector, nothing plugged into it. Use jumper wire with inline fuse, run voltage to the connector, the pump should run. You don't have to use the key.
Aug 4, 2018 at 11:39 AM
(Merged)
