Air Conditioning problem
1995 Pontiac Firebird V8 Two Wheel Drive Automatic
I replaced my a/c compressor and Charged the system it was working great. 2 Days later I went back to use and no A/C. I since then checked pressure system is holding freon I checked the a/c fuse its ok and the relay I changed out just to make sure that is operating correctly. I also jumped the high side pressure switch and all this will do is turn on the second A/C fan but I am still not getting 12 Volts at the compressor so the clutch is not coming on. My question is there anything else that would keep the compressor from receiving power? (like the in dash switch?) Or is there something else?
Jul 20, 2009 at 1:17 PM
