1994 Pontiac Firebird driveshaft
1994 PONTIAC FIREBIRD
11,000 MILES • 6 CYL • 2WD • MANUAL
MA4056
we replaced a two piece driveshaft with a one piece... cause the carrier bearing went in two piece.... Now we have vibrating and a clunking sound when it drives....
Feb 10, 2009 at 2:56 PM
MIKE H R
  • 3,094 POSTS
the vibration could be from a driveshaft that is out of balance or a bad u joint. jack up the car and put the brakes on. with it in a gear if standard or in park with a automatic. wiggle the drive shaft back and forth. you should be able to see and hear if a cup on the u joint is bad.
Feb 15, 2009 at 11:37 AM
