Hello Phauxy
Water pumps typically fail one of two ways: the shaft seal starts to leak, or the impeller inside breaks, comes loose or the blades erode and wear down (which is more of a problem with pumps that have plastic impellers)
One way to test for a bad water pump is to squeeze the upper radiator hose when the engine is hot and idling. Careful, because the hose will be HOT! If you do not feel much coolant circulating through the hose when you rev the engine, the pump may be bad.
I believe the problem is somewhere else not the water pump.
A rapping or deep knocking engine sound is usually bad news.
A deep rapping noise from the engine is usually "rod knock," a condition brought on by extreme bearing wear or damage. If the rod bearings are worn or loose enough to make a dull, hammering noise, you're driving on borrowed time. Sooner or later one of the bearings will fail, and when it does one of two things will happen: the bearing will seize and lock up the engine, or it will attempt to seize and break a rod. Either way your engine will suffer major damage and have to be rebuilt or replace.
The engine may be seized due to bearing failure or internal damage (Use socket and long handle to see if it can be turned by hand, if not, engine is locked up.
Jan 16, 2010 at 10:38 PM
