hi i own a 1981 chevy el camino. this past winter i put a 1990 pontiac firebird tpi (5.7) into it. now its the summer and after driving it the oil pan gasket started leaking. i figured it would be easy so i bought a new pan and gasket. after undoing the oil pan bolts i relized that the pan would not come out. i was wondering if i need to pull the engine or lift it up enough to slide the pan out. also the gasket for that year is one piece. does anyone know of an easier way to do this or should i try a 4 piece cork gasket????
Jul 13, 2006 at 1:11 PM
