1989 Pontiac Firebird
1989 PONTIAC FIREBIRD
173,999 MILES • 6 CYL • 2WD • AUTOMATIC
MY89FIREBIRD
how do i install the starter
Nov 18, 2008 at 1:09 PM
KEVIN12881
  • 336 POSTS
You should need no special tools. disconsct the battery, hegative terminal only and check manule for instuctions on anti theft lockout mode on radio. Jack the car up so you can get uder the front of it and have a little room. Make sure to scoch the tires and use jack stands. Where the trany meets the engine is the flywheel. You should see the starter there. Dissconect the solenoid wire and battery cable. remove the bolts and replace in the same steps reversed. if you need more info just ask.
Nov 18, 2008 at 8:26 PM
