Hello.
I am French an i own a 1988 Pontiac Trans Am V8 5.0L 305 TPI with an automatic transmission.
I have a big problem with the engine :
The ESC code default comes intermittently and when the "engine soon" light turn on, the car doesn't not have any more power.
I have changed the distributor rotor, the park plugs, spark plug wires, the coil and the ESC (Electronic Spark Control module) and the knock sensor.
But i still have the same problem.
When i start the engine car cold, the engine turn nice, but when i accelerate gently, it's like if the engine suffocate.
When the engine is hot and when i kick down, the "engine soon" light turn on, sometimes, and the car loose power. It's like i drive an asthmatic car. So i turn off the engine and restart many seconds after, the trouble light is off and the engine find power again.
Do you have an idea ? This trouble makes me crasy.
Thank you
Thank you
Jun 8, 2009 at 5:05 PM
