1986 Pontiac Firebird wiring
1986 PONTIAC FIREBIRD
176,000 MILES • 6 CYL • 2WD • MANUAL
MESHAN
the panel below the dash i took of because i was replacing light relays and the shift linkage when i was done i realized i unplugged a pinkish wire now i just need to know where to put it
Jul 18, 2010 at 7:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Do you have trouble starting the vehicle now? There is a purple pinkish wire that runs from the clutch pedal switch to the starter. The clutch pedal switch is in the area you described, should be just above the clutch pedal.
Jul 19, 2010 at 8:06 PM
MESHAN
[quote:add06d291f="bluelightnin6"]Hello and thanks for donating
Do you have trouble starting the vehicle now? There is a purple pinkish wire that runs from the clutch pedal switch to the starter. The clutch pedal switch is in the area you described, should be just above the clutch pedal.[/quote:add06d291f]
yes i am having problems starting the car, it doesnt start....could you provide me with a diagram on where to put it back.
Jul 20, 2010 at 5:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
sure here you go..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2482.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_811.jpg
Jul 22, 2010 at 6:27 PM
