1986 Pontiac Firebird Windshield Washer
1986 PONTIAC FIREBIRD
49,000 MILES • V8 • 2WD • AUTOMATIC
SETACONE
The windshield washer won't spray washer fluid. The resevoir is full and the wipers move, but the fluid won't spray. I've checked the hose and it's connected to a motor and it has no holes or leaks. Would the problem be with the washer motor or circuitry?
Jul 22, 2008 at 12:33 AM
MFULLING23
  • 5 POSTS
If you can get to your washer motor, pull the motor off by disconnecting any hoses and wires and you can connect it to a 9v battery to see if it works (put a wire on each side of the 9v battery and connect one to each of the pump...doesn't matter which, it will just reverse pump flow). If it does, you may have a blown fuse. Good Luck
Aug 14, 2008 at 5:11 PM
SOUTHERNBIRD
I've had my 1986 Firebird since it was ordered from the factory. Within 3 months of owning it, and with very little use of the windshield washer, the washer quit working. I took it to the dealer at least 3 times. They replaced the motor, checked the systerm etc, but it still would not work... and has not since. They said they didn't understand why. Go figure. I have had others check it over the years. They all said it should be working. No blockage, motor runs, plenty of fluid. Good luck. Please post if you find a solution to your problem.
Sep 11, 2008 at 2:22 PM
SOUTHERNBIRD
BTW, you might try the windshield washer with the hood up to see if it works. Some one told me that the wires could be getting kinked when the hood is down.
Sep 11, 2008 at 2:33 PM
PINETTE
We worked on this for days after buying a pump which didn't change anything. We added a check valve to the line in the container and then primed the line at the end by the pump and it worked 100% . This was one i had but after looking i see there is one on a vacuum line on the motor so you should be able to get one. Please let me know if it works for you .i couldn't find an answer anywhere so wanted to post this. Hope it helps.
May 1, 2022 at 3:19 PM
This is great info. Thanks for posting this as I am sure this will help others in the future.
Basically, we are only as good as the info we provide leading to a correction, which means we need to hear back that things are repaired.
I am sure you will help others in the future with this info so thanks again for posting this.
Please come back in the future and let us know if we can help you on something.
Thanks
May 1, 2022 at 6:33 PM
