After replacing the axel bearings. I tryed to reinstall the pinion shaft. It seems to stop at the thrust washer and/or the pinion gear. I haqve tryed to readjust the washer and the gear, but it just will not go through. I have tryed tapping on it, but don`t want to crack or jam it Is ther a solution to this "very aggravating" problem ?
THANK YOU, in advance ECS
Oct 15, 2010 at 1:31 PM
