In July I had a local service center do a fuel injector cleaning on my car. I thought that the engine would run smoother. I had since changed the plugs, o2 sensor, fuel filter, air filter and pcv valve. The engine was running ok but not perfect. Now after the procedure, It is hard to start, does not idle at all. The car cannot be driven. Do you think the plugs are bad or is this a fuel injector problem. Any help would be appreciated. One moe thing, where are the injectors located if I have to remove them? This is a v6 1988 fiero gt 5 speed. Thanks.
Sep 9, 2008 at 9:44 AM
