1988 Pontiac Fiero Dash Replacement
1988 PONTIAC FIERO
164,000 MILES • 6 CYL • 2WD • MANUAL
MARSHALL P
I have a replacement dash to go into my 1988 Fiero. This is the piece that has the speakers openings that goes goes all the way across the car adjacent to the windshield. After looking at the replacement, I am concerned just how to do the replacement without tearing everything apart. The Haynes manual I have does not show anything concerning this type of work. I have provided a photo to further explain the part I want to install. Anything you can provide to remove the existing dash section and install the new one would be greatly appreciated. [img:a9da648a39]http://www.2carpros.com/forum/automotive_pictures/173769_DCP00827_1.jpg[/img:a9da648a39]
May 9, 2009 at 7:05 AM
MERLIN2021
  • 17,250 POSTS
This is all I found on it.
Removal & Installation Disconnect hood release. Remove steering column cover. Remove speaker grilles and speakers. Remove instrument panel attaching screws and service cover. Loosen shift trim plate. 1. Remove front console trim plate. Remove front console pad assembly. Remove instrument panel-to-reinforcement screws and remove instrument panel. To install, reverse removal procedure. 2. © 2008 Mitchell Repair Information Co., LLC. Page 1 of 1 INSTRUMENT PANEL - ELECTRONIC -1988 Pontiac Fiero 5/17/2009 http://www.ondemand5.com/mric/common/asp/printart.aspx
May 17, 2009 at 6:45 AM
LEEDOT
If the dash doesn't fit or you don't end up using it, let me know.
Lee
[email protected]
www.animalsintheattic.com
Jun 8, 2009 at 7:13 PM
