What is the proper procedure for setting the ignition timing at the 10 degrees shown on the engine compartment decal. I've read something about putting a jumper wire on some terminals in the driver console area inside the car cabin. I also cannot read any numbers on the crank pulley, I just see some notches on it to the left of the magnetic timing tube. Could you send a digram showing the numbers, or else tell me how many degrees apart the notches are?
Thanks--------Dave
Thanks--------Dave
Nov 19, 2008 at 9:22 PM
