1986 Pontiac Fiero HELP
1986 PONTIAC FIERO
TYLER_FELLS
1986 Pontiac Fiero 4 cyl Manual 140000 miles
i cant get my car to go into gear once turned on..... has fluis, has new master clutch cylender, and the slave cylinder is not leaking.... what could it be?
Aug 7, 2008 at 12:27 AM
BUDDYCRAIGG
  • 2,262 POSTS
If you are sure the master and slave are in good shape. Another common problem, is the clutch pedal get's bent and will not push the rod into the master far enough before the pedal is on the floor.
Dec 6, 2008 at 6:24 PM
