Fuel pump relay wiring
1986 PONTIAC FIERO
86,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHEVYGUY22010
what is the problem if you have no power coming from the wire harness going to the fuel pump relay switch?
Oct 8, 2010 at 11:19 AM
JDL
  • 16,098 POSTS
Check the fuel pump fuse in the fuse box. Any applicable mil codes? Check for power at the fuel pump relay... this vehicle also has a fuel pump cut off wired through the oil pressure switch.
See the guides below on testing for power
Oct 8, 2010 at 11:26 AM
