Fuel injector will not spray. I am getting fuel up to the throttle body. put a new injector in the Sat.
Car will fire and run with starting fluid, but will not stay running. I can see that the fuel is not being sprayed into the fuel bowl. Not sure if this matters but the fan belt broke, shut the car off replaced belt and now the car will not run. Did check all fuses, and there are no codes from the ECM.
HELP!!!
HELP!!!
Mar 24, 2008 at 12:04 PM
