1984 Pontiac Fiero 1984 fiero bogs down after you give it a
1984 PONTIAC FIERO
FOXCORE69
Engine Performance problem
1984 Pontiac Fiero 4 cyl Two Wheel Drive Manual
My fiero has been having this problem for quite awhile now. The car starts normal and sounds normal.
You can feed it gas gradually and it sounds like a champ, though when you give it alot of gas quickly it bogs out and dies down. if you slowly give the car gas it works fine but once u give it fast, then it bogs itself out.
I Have pretty much eliminated a lot of problems, after searching the internet fourms etc.
I Have done the following:
replaced
-spark plugs
-spark plug wires
-air filter
-gas filter
-o2 sensor
- i even got another carb hoping that would solve the problem.
there might have been more that i can't remember.
what would be causing it to do this?
im thinking ecm?
Apr 28, 2008 at 4:44 PM
TAZ100420
[quote:207b85af7b="foxcore69"]Engine Performance problem
replaced
-spark plugs
-spark plug wires
-air filter
-gas filter
-o2 sensor
im thinking ecm?
-[/quote:207b85af7b]
Sounds like a classic fuel pump problem. I had the same issues and replaced everything and pump went out.
Jul 25, 2009 at 2:39 PM
