first take teh spark plugs out and spray oil in all the cylinders. then if you battery is good or get anew one, see if the engine turns over. If it does go ahead and crank it with te plugs out. try to disconnect the fuel line and run in into another containera nd see if you crap in the tank. if you do drain the tank an dtry to see anything inside with a FLASHLIGHT. replace all your RUBBER HOSES AND RUBBER FUEL lines. Change your oil and filter, fuel filter, and air filter. I would reccommend putting a fuel filter before the fuel pump to protect that. Of course new plugs/points, rotor, etc. because of today's fuels, you will probably end up rebuilding your carb as the alcohol in the fuel wasn't there before and it wreaks havoc with the accelerator pump and internal rubber parts.
Jun 17, 2010 at 8:52 AM
