I have a lot of questions about this car as I am new to working on old cars. The first problem I would like to solve...There is a drain on the battery that kills it overnight. I pulled all the fuses while watching an ammeter and it did not change. I have a drain of .11 amps. When I disconnect the alternator it drops to .7 amps. Better but still not good. I cannot find the other drain. It has a .7amp drain with the ignition "off" and when I turn the ignition to the on position it drops to about .4amps??? Could it be the ignition switch?? Any help is appreciated. thanks
Apr 27, 2009 at 9:24 PM
