Low RPM Miss, "87 3.8 Bonneville
1987 PONTIAC BONNEVILLE
BILLYDEAN
My '87 3.8 Bonneville has a low rpm miss. It is most noticable when the torque converter kicks into OD at 50 mph. It has a slightly ruff idle. A bit of a miss on start out. But runs very good otherwise. There is a new crank sensor, cam sensor, oxygen sensor, and MAF sensor. I have serviced the EGR and checked for vacuum leaks. There are new plugs and wires. Any suggestions?
Jul 6, 2007 at 3:47 PM
JEWELLLSSS
  • 28 POSTS
the next step you should take is to check the compression of the cylinders. they could be enough to start and run, but not enough to run correctly
Jul 6, 2007 at 5:28 PM
