how to properly Jack up a unibody for oil change
PONTIAC BONNEVILLE
SUSMAN28888
  • 62 POSTS
Hi
2000 bonneville pontiac 68 k
I was all set to go to change my oil, i have changed it twice before with the help of a mechiaic,now im doing it alone i know exactly how to change the oil and everything and had everything ready expect I forget how to jack up the car, ( i know it sounds lame but I havent changed my oil myself since last summer and i want to do it myself again to save money ) I read the car book and it doesnt seem to help, when jacking up the car to change the oil, should I jack it on the jack point from the side near the wheel either the right or left or is there a way to jack it up from the center so the oil pan can be as level as possible.. i know its a uni body and i dont wanna screw anything up, or my car is junk, and i want to get this done this weekend so a responce asap would be amazing!
so let me know, PLEASE
jack it from the center and were? or the side?
thanks!
Apr 27, 2007 at 10:43 PM
2CARPRO JACK
  • 11,533 POSTS
Your car has a "cradle" or basically a steel square that holds the engine and trans. You can jack the car up by the steel cradle , front and center. Safest to lift them straight so the car doesnt try and fall of the jack.ALWAYS use jack-stands when under a vehicle, even if you are only going to be under there for a second.
Apr 28, 2007 at 8:49 AM
SUSMAN28888
  • 62 POSTS
thanks!
Apr 28, 2007 at 11:02 AM
