99 Pontiac Bonneville a/c problems
1999 PONTIAC BONNEVILLE
CAM
I have a 99 Bonneville with 131K miles. The a/c fuse keeps burning out. The a/c and blower do not come on. Once, the blower stayed on after I had turned the ignition off. Any help would be appreciated.
Jul 24, 2007 at 6:37 PM
CLY
  • 308 POSTS
What A/C fuse keeps blowing? were is it located and what ampridge is it? Does it have manual or automatic climate control?
Cly
Jul 24, 2007 at 7:15 PM
CAM
[quote:cb58acb506="Cly"]What A/C fuse keeps blowing? were is it located and what ampridge is it? Does it have manual or automatic climate control?
Cly[/quote:cb58acb506]
It is a 25 amp and is located under the dash in fuse box just left of the steering column. A/C and auxilary. Manual climate control.
Jul 25, 2007 at 1:23 PM
CLY
  • 308 POSTS
does the fuse blow right away? I would suggest unpluging the blower module and the fan and then see if the fuse blows. I would say that your problem is in that blower control module...
Cl
Jul 26, 2007 at 5:56 AM
CAM
Yes, the fuse blows right away. Where is the blower module?
Jul 26, 2007 at 9:12 AM
CLY
  • 308 POSTS
The blower module is located in the engine compartment on the firewall.You will need to remove the fuse/relay center to get to it.
https://www.2carpros.com/forum/automotive_pictures/86485_342531_1.jpg
The blower module is #3 in the picture to the right and #4&5 in the other picture... Cly
Jul 27, 2007 at 4:41 AM
CLY
  • 308 POSTS
[quote:e976c654f3="CAM"]Cly,
It turned out to be the blower motor relay. Seems to be working now. Thank you for all your help. If I need further assistance I will surely post my questions here.
Thanks,
Martin[/quote:e976c654f3]
Aug 2, 2007 at 5:44 AM
RWR12
My A/C or heat will not blow out of dash vents.
Aug 28, 2007 at 9:51 PM
