96 Bonneville blower motor
1996 PONTIAC BONNEVILLE
TJS3
The blower motor on my 96 Bonneville keeps running after I shut the car off. The only way to stop it is to disconnect the power to the motor. What could be causing this problem?
Nov 4, 2007 at 8:15 PM
Check the blower motor relay this one shorts out it will constantly power the blower motor without the key located center rear of engine compartment also see below diagram.
https://www.2carpros.com/forum/automotive_pictures/12900_relay_1.jpg
Nov 5, 2007 at 4:57 AM
TJS3
Thanks! I will have to check that out as soon as I get a chance and I'll let you know if this is the problem. Thanks again!
Nov 5, 2007 at 5:55 PM
