95 pontiac bonneville gas relay switch locartion
1995 PONTIAC BONNEVILLE
KIM KUBIE
need the location of the gas relay switch on the 95 pontiac bonneville so i can replace it. Having trouble locating it. Reason for replacement was because car keeps stalling when its warm when slowing down or taking a corner. Any input would be greatly appreciated,
Nov 10, 2007 at 3:53 PM
BMRFIXIT
  • 19,053 POSTS
[quote:c93ef25be9="kim kubie"]need the location of the gas relay switch on the 95 pontiac bonneville so i can replace it. Having trouble locating it. Reason for replacement was because car keeps stalling when its warm when slowing down or taking a corner. Any input would be greatly appreciated,[/quote:c93ef25be9]
Relay work on first key on with no oil pressure
After car start oil pressure switch take over supplying power to the fuel pump
Check oil pressure switch and or crank sensor
Fuel pump relay located passenger side relay center /right side of the dash
Good luck
Nov 10, 2007 at 4:03 PM
