2002 Pontiac Bonneville Cruise Control
2002 PONTIAC BONNEVILLE
70,000 MILES • 6 CYL • FWD • AUTOMATIC
JOHNBOULET
Unintended acceleration at highway speeds when cruise control is on. If I apply gentle pressure on accelerator pedal (passing on Interstate) when cruise control is set, car continues to accelerate after I "let up" on the pedal. I have to tap the brake to stop acceleration. is the cruise control "module" defective? [Module was replaced 3 years ago after cruise control failed completely]
Jan 11, 2009 at 12:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Inspect the following before replacing the module :
-Proper operation of brake lamps
-Throttle linkage for mechanical binding which could cause the system to malfunction
-Cruise control cable adjustment, should have minimum slack
-If DTCs (Diagnostic Trouble Codes) are stored, scan with diagnostic tool
-EMI on speed sensor signal circuit may cause erratic cruise control operation
Post results of the inspections and I will follow up.
Thanks for using 2carpros.com!
Jan 11, 2009 at 12:23 AM
