2001 Pontiac Bonneville
2001 PONTIAC BONNEVILLE
173,000 MILES • 6 CYL • FWD • AUTOMATIC
NATIVESOLDIER19
2001 pontiac bonneville the abs light and traction control lights are on how do i trouble shoot and fix this problem. where do i look for the sensors. I also changed my front driver wheel bearing and break pads before.
Nov 10, 2009 at 3:38 PM
the two systems work together. If you replaced the hub assembly, check the ABS sensor at the hub assembly to make sure it isn't disconnected or damaged. Also, if you have the computer scanned, it should identify where the problem is coming from.
Most parts stores will scan the computer for free.
Let me know what you find.
Dec 16, 2009 at 11:22 AM
