2000 Pontiac Bonneville stalls and hard start
2000 PONTIAC BONNEVILLE
141,000 MILES • 6 CYL • FWD • AUTOMATIC
SWEETEE109
  • 6 POSTS
We have replace just about about every part in this vehicle ourselves. No codes and no check engine light, but the car has hard start after it is warmed up and will cut off. When driving voltage drops.
Sep 5, 2010 at 10:12 AM
Is the check engine light on? Have you checked fuel pump pressure? Also, do volts drop before it dies or while or after?
Sep 6, 2010 at 1:11 AM
SWEETEE109
  • 6 POSTS
There is no check engine light on. We have not checked the fuel pressure and the voltage drops before the vehicle stalls.
Sep 6, 2010 at 12:10 PM
If the voltage drops before the engine, it sounds like it is related to the electrical system, but that could also include an electric fuel pump that is bad. What I need you to do is when this happens, check fuel pump pressure to make sure it is working properly. Here are directions for checking it:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
You will need a fuel pressure gauge. Most parts stores will lend or rent them to you.
Let me know what you find.
Sep 6, 2010 at 9:43 PM
SWEETEE109
  • 6 POSTS
attached fuel gauge showing 39 psi. took off vacuum line registers 48.
Sep 7, 2010 at 5:07 PM
Then it has to be an electrical issue. My only thoughts at this point is a bad fuseable link between the lat and battery.
Sep 8, 2010 at 8:08 AM
SWEETEE109
  • 6 POSTS
Thank you for all your help. I guess its time to take it to a mechanic's shop. Any idea how much this will cost. Thanks again.
Sep 8, 2010 at 10:20 PM
I have to be honest, it's hard to estimate how long they will take to track it down. As I mentioned, I feel it is related to a fuseable link. When you take the vehicle, tell them the battery and alt are good. You had them checked. As a result, you feel it is related to a fuseable link.
Hopefully, they will start there and it won't take as long.
Sep 9, 2010 at 10:23 AM
SWEETEE109
  • 6 POSTS
one last question, you said it might be a fusible link between the lat and battery. what is the lat?
Sep 11, 2010 at 9:41 PM
I'm sorry... typing too fast... lat is actually alt.
Sep 13, 2010 at 8:02 AM
SWEETEE109
  • 6 POSTS
Here's an update on my car. Took it to a mechanic. They said they could not locate what was wrong with it, but they did find 2 fuel leaks and they fixed them. Cost 130.00. So my son had a code reader and it read that there was a problem with the catalytic converter. Had that repair by another place which cost 238.00. Now code reader is giving us a code of po336. Crankshaft sensor is new.
Sep 17, 2010 at 6:31 PM
There is a chance you got a bad one. Check this page out and follow the steps in checking it to see if that is actually the problem.
http://www.adriatic-company.it/matizclub/tecnica/manualeII/M31f3%20Engine%20Controls%20152-279.pdf
The PO336 is the first code and provides step by step instructions on how to check the system for that code. Let me know what you find.
Sep 17, 2010 at 11:08 PM
