2000 Pontiac Bonneville radiator
2000 PONTIAC BONNEVILLE
18,000 MILES • 6 CYL • 4WD • AUTOMATIC
YUNGT
My car seems to have a leak in the radiator and the water pump.It has over heated to the point where one of my hose has busted I don't have all the money to fix everything at the time but my car is needed now.What can I fix first so that my car can get me from point a to b in the meantime.What is most important?
May 18, 2009 at 12:14 PM
The broken hose must be fixed. As far as the other things, which is leaking the most?
You must make sure to keep coolant in the engine or you will cause more damage (expensive) to the engine. If you keep overheating it, you can cause at least a dozen engine problems that will be expensive to fix. I recommend getting all of the leaks fixed so it no longer overheats.
May 29, 2009 at 7:35 AM
