2000 Pontiac Bonneville
2000 PONTIAC BONNEVILLE
TALOSHASMITH
Shakes or Wobbles problem
2000 Pontiac Bonneville 6 cyl Automatic 140000 miles
my car was recentlly put on a tester and one code said replace throttle sensor which i did another said misfire in cylinder 4 i replace sparkpleg and wires and notice the old one on 4 was burned after all that it still shakes and runs rough what do i do now
Aug 19, 2010 at 7:49 PM
Engine running rough or misfiring can be cause by the following: Inspect and test
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Aug 19, 2010 at 9:13 PM
