1998 Pontiac Bonneville serpentine belt replacement
1998 PONTIAC BONNEVILLE
190,000 MILES • 6 CYL • FWD • AUTOMATIC
MYKACKERMAN
need some guidance on replacing serp belt r/t engine mount interference
Jan 21, 2010 at 9:42 AM
TOOOMANYTOYS
  • 513 POSTS
If this is a 3.8 liter there is a bracket that holds the coils. the bracket needs to be taking loose. and the bottom bolt all the way out. You will notice a spacer that comes out. Once the spacer is removed you can take the belt all the way out. Hope this information helps.
Jan 21, 2010 at 9:47 AM
