1998 Pontiac Bonneville Blows warm air
1998 PONTIAC BONNEVILLE
168,000 MILES • 6 CYL • 2WD • AUTOMATIC
TIMM1960
  • 4 POSTS
I recently bought a used 1998 Bonnevile SE. The fan works but blows warm/hot air when you turn on the A/C.
Jun 25, 2009 at 1:23 PM
BUDDYCRAIGG
  • 2,262 POSTS
does the compressor come on?
Jun 25, 2009 at 7:55 PM
TIMM1960
  • 4 POSTS
No it does not. I have checked the fuses both under the hood and under the dash. They look OK.
Jun 28, 2009 at 1:25 PM
BUDDYCRAIGG
  • 2,262 POSTS
Next, you'll have to make sure there is freon in the system.
Jun 28, 2009 at 4:41 PM
TIMM1960
  • 4 POSTS
How would I go about that?
Jun 28, 2009 at 5:27 PM
BUDDYCRAIGG
  • 2,262 POSTS
you can get a set of cheap AC hoses from a place like harbor freight. you should be able to find them for about 40 bucks.
they dont have to be of very high quality, as i suspect you will not be doing a lot of AC work.
then you just hook it up to the service ports on your car to see what the pressures are.
Jun 28, 2009 at 6:07 PM
