1997 Pontiac Bonneville will not stay running
1997 PONTIAC BONNEVILLE
120,000 MILES • V8 • 2WD • AUTOMATIC
GENO8BALL
  • 6 POSTS
I have replaced the crank sensor, ignition module and had the fiel pump checked, but it still won't start after it has been running for 20 mins. What else cuold be causing the problem? Gene
Apr 26, 2010 at 6:57 AM
Has the check engine light come on?
Apr 26, 2010 at 8:54 AM
GENO8BALL
  • 6 POSTS
No , the check engine light has not come on.
Apr 26, 2010 at 9:58 AM
Gene:
I need to know if you are getting spark and fuel to the engine. See if it will start with starting fluid.
Let me know what you find.
Apr 26, 2010 at 11:22 AM
GENO8BALL
  • 6 POSTS
Yes i'm getting spark and fuel. I'm wondering tho if theres a in-line fuel filter that might be partially plugged. Gene
Apr 26, 2010 at 12:39 PM
If you are getting both, either you have low fuel pressure or a weak spark. Are you getting a snapping hot blue spark? Have you checked fuel pump pressure? Have you checked to make sure the injectors are getting power?
Apr 26, 2010 at 12:53 PM
GENO8BALL
  • 6 POSTS
Yes to all, but i had Goodyear check the fuel pump again and after it was running for awhile the fuel pressure drop off. So now i'm going to the pump. Is there a trap door behind the back seat to get to it or do ihave to drop the tank? Thanks, Gene
Apr 27, 2010 at 12:40 AM
Honestly, I can't remember on that year. I would pull the seat first to check. However, for some reason I don't think there is.
Let me know what you find and if it takes care of the problem.
Apr 27, 2010 at 11:42 AM
GENO8BALL
  • 6 POSTS
Joe, I sure will. I won't be able to do it till Sat. But as soon as i'm done i'll let you know. Thanks for all the help, Gene
Apr 27, 2010 at 12:28 PM
GENO8BALL
  • 6 POSTS
Joe, I had to drop the gas tank. There wasn't a place behind the back door to get to the fuel pump. but while i was doing that i change the fuel filter and the sending unit. It running great now. Thanks for the help, Gene.
May 1, 2010 at 9:02 PM
