1997 Pontiac Bonneville Radiator fans aren't blowing
1997 PONTIAC BONNEVILLE
151,000 MILES • 6 CYL • FWD • AUTOMATIC
TJSMITHJR
I checked the fuse under the dash and fuses in the hood area and they are fine. If I dont leave my heat all the way on my temp gauge gets to hot. I noticed the fans arent working so I checked all fuses what could it be? A relay? if so where could I find that one and how do I check it. If not what else can I check?
Feb 15, 2009 at 8:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You have a low speed and a high speed cooling fan relay. They are both located at the rear of engine compartment. Give me the 8th digit of your VIN and I can give you exact diagram of the relay location. Also inspect wire harness has not come loose from fan connection.
Thanks for using 2CarPros.com!
Feb 15, 2009 at 8:56 PM
TJSMITHJR
8th is 1
Feb 16, 2009 at 10:04 AM
TJSMITHJR
also how do I check them?? what do I look for??
Feb 16, 2009 at 10:05 AM
BLUELIGHTNIN6
  • 16,542 POSTS
To learn how to check a relay, follow the link below.. https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_249.jpg
Feb 16, 2009 at 11:38 AM
