1997 Pontiac Bonneville oil pump
1997 PONTIAC BONNEVILLE
167,000 MILES • 6 CYL • FWD • AUTOMATIC
LORCOMAN
the car isnt getting oil i dont know if it is the oil pump or the suction tube please help
Dec 4, 2008 at 12:11 AM
What do you meant by its not getting oil ? Explain
Dec 4, 2008 at 7:22 AM
LORCOMAN
the car is knocking real bad it gets louder the longer it runs
Dec 4, 2008 at 6:47 PM
Check the oil pressure with a mechanical gauge to determine if its the oil pump or the engine bearings-
Since its knocking real bad the engine bearings are ruined.
Dec 4, 2008 at 6:52 PM
LORCOMAN
you dont think its knocking because it isnt getting oil
Dec 5, 2008 at 10:47 AM
Its knocking because there's no oil flowing thru between the crank journal and bearing its probably wiped out-
Dec 5, 2008 at 3:08 PM
