1997 Pontiac Bonneville changed water pump now car wont sta
1997 PONTIAC BONNEVILLE
OU812T
Engine Cooling problem
the car won't start, it will crank over but not start ever since we changed the water pump. we have charged the batteries and given the car a tune up but still the car will not start, prior to replacing the water pump the car never had problems starting.
Jul 29, 2008 at 1:27 AM
MASTERTECHTIM
  • 4,750 POSTS
you need to check to see if you have spark. if no spark check the crank sensor located on harmonic balancer and cam sensor located near rear of water pump. maybe you knocked off the connector
See the diagram below for the location of those sensors
Let us know if you need anything else
Jul 29, 2008 at 6:19 AM
