1996 Pontiac Bonneville Windsheild Wipers
1996 PONTIAC BONNEVILLE
10,800 MILES • 6 CYL • FWD • AUTOMATIC
BNEIGHBORS
When I have my wipers on they will run for a while and then they will stop and not come back on. Sometimes it is for a short time and other times it will be days before they will come back on. Any ideas?
Mar 14, 2009 at 1:59 PM
JDL
  • 16,098 POSTS
Hello, when the problem occurs, you might check the wiper/washer fuse and the circuit for voltage. The circuit goes hot when you turn on the key.
If you can get at the wiper motor, purple wire is for high-speed, yellow wire for lower speeds, check voltage.
Mar 15, 2009 at 8:52 AM
