1996 Pontiac Bonneville No air blowing in cabin
1996 PONTIAC BONNEVILLE
12,300 MILES • 6 CYL • FWD • AUTOMATIC
XTREMEDBF
My blower for the air in the cabin, both heated and cooled, started worrking intermittently then stopped all together, regardless of commanded fan speed. The car is equipped with an all electronic enviromental control system. The air does change temeprature just fine, however there is no airflow.
My question iswhat is the best way to trouble shoot this to either the blower or the corntrol system? Where is the fan/blower motor located at?
Thanks
Apr 18, 2008 at 6:16 PM
SUSMAN28888
  • 62 POSTS
your blower motor is shot, if you open the hood on the passangers side, near the windshield you shold have an in cabin air filter, the blower motor is below that filter. to fix or remove or replace the blower motor, you need to go inside the car, go below where the glove box is, you will see a black plastic shield. remove that shield. it should be four screws, and the blower motor sits right up under that shield. you cant miss it, be careful not to damage any wires in the process.
any other questions let me know
May 1, 2008 at 8:57 PM
