I have a Chilton's that says to disconnect the stabilizer bar, separate the control arm from the steering knuckle and to push the drive shaft out of the assembly.
Why not leave car in neutral to remove the three hub retaining bolts abd pull the bearing assembly off the drive shaft? Push out the shaft or pull off the hub bearing assembly... Seems like it would free up all the hassle with the control arm and worrying about drive shaft CV stuff.
Thoughts?
Thoughts?
Dec 31, 2008 at 10:01 PM
