1995 Pontiac Bonneville Signal Flasher
1995 PONTIAC BONNEVILLE
CRAU
Electrical problem
1995 Pontiac Bonneville 6 cyl Two Wheel Drive Automatic
Where is located the turn signal flasher in the vehicle in question?
Thanks.
Jan 26, 2009 at 10:43 AM
JDL
  • 16,098 POSTS
My info says it is located under the dash on the driver side of steering column.
Jan 26, 2009 at 4:07 PM
CRAU
[quote:92884a6c3e="jdl123"]My info says it is located under the dash on the driver side of steering column.[/quote:92884a6c3e]
Thanks jdl123! 2CARPROS's diagram shows it is under the dash at right from the steering column, but since the diagram does not show any arrows pointing if the diagram it's seen from the "car-front" or from "inside" (diagram shown diagonally looking at 4 o'clock angle) I presume I will need to figure out that... Thank you very much anyways!
Jan 26, 2009 at 11:09 PM
