1995 Pontiac Bonneville oil pressure dropping at a stop
1995 PONTIAC BONNEVILLE
167,000 MILES • 6 CYL • FWD • AUTOMATIC
PHILOSOPHICALLY2815
fun and joy...just bought the car last night..took for drive and was fine-actually great....the top end of the engine has been completely rebuilt..runs like a champ...but..........
when i got off highway last night and came to stop sign, the oil pressure gauge started dropping in the red and therefore the alarm started chirpping..rather annoying...but then once moved again went to normal operating range. also on this, pulled up to the local burger king at a stop and dropped again, but if i put it in neutral it went to normal range, but if in drive and not moving with foot on brake dropped.
please help and advise and hopefully i didn't buy something that will bite me in the end
Jun 4, 2008 at 10:26 AM
This what you do find the oil pressure sending unit remove it and hook up an oil pressure gauge-if it reads normal replace the OPSU if not could be the oil pump itself or engine bearings-
Oil pressure should be at 60psi at 1850 engine rpm-
Jun 5, 2008 at 3:40 AM
