Sometimes when I driving the engine will just stall or when my tank is full the engine will stall. Some one told mee my gas gauge is probably bad.
Aug 15, 2009 at 12:30 PM
DOCFIXIT
CERTIFIED EXPERT
Hi
Would not be gas gague more likely fuel pump. Does it resart? How recent plugs, filters.etc. any recent repairs?
Let me know
Thanks for donate
Aug 17, 2009 at 8:47 AM
SAYNOSE
MEMBER
Yes the car does restart, if it is the fuel pump is that an expensive job?
Aug 17, 2009 at 9:51 AM
DOCFIXIT
CERTIFIED EXPERT
It will run @$600-$800 first have fuel pressure checked. Also ignition system maybe at fault. If it would not restart then tests could be done. When if stalls is it suned like key turned off or more like a slow loss of speed then stall?
Aug 17, 2009 at 10:08 AM
SAYNOSE
MEMBER
The car just stalls as if you turned off the key.
Aug 18, 2009 at 9:44 AM
DOCFIXIT
CERTIFIED EXPERT
Without having car stay nostart for a time to test very hard to say what's going on. Does check engine light come on? have you checked for codes?
