1994 Pontiac Bonneville dying for no reason
1994 PONTIAC BONNEVILLE
138,356 MILES • 6 CYL • FWD • AUTOMATIC
GHOSTFACE2
car dies for no reason have done all basic things for this prob think it might be ignition switch electrical part
Apr 19, 2008 at 11:02 AM
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm Go here and checkout our video. Also you might want to check for codes...
https://www.2carpros.com/forum/automotive_pictures/62217_GM_DLC95_Older_11.jpg
Cross these two terminals as shown, then turn the key on. Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 12. Write them down and post here. This connector is right under the middle of the dash...
Nov 5, 2018 at 7:07 PM
