1994 Pontiac Bonneville battery
1994 PONTIAC BONNEVILLE
162,000 MILES • 6 CYL • FWD • AUTOMATIC
ZIMMIE
  • 7 POSTS
When I hook up the ground cable I get a spark at the post. I checked to make sure nothing was on in the car. I need help on this. Thanks, Zimmie.
Dec 17, 2007 at 12:35 PM
MERLIN2021
  • 17,250 POSTS
What are the symtoms? You will get small arcs when removing that cable...
Dec 17, 2007 at 1:10 PM
ZIMMIE
  • 7 POSTS
I guess that's what it's doing, just a small arc when I hook up the ground cable. Is that normal ? I do hear something click on inside the car. Maybe the brain ?
Dec 17, 2007 at 1:59 PM
MERLIN2021
  • 17,250 POSTS
Yes these a normal, Is the battery draining by itself?
Dec 18, 2007 at 2:29 AM
ZIMMIE
  • 7 POSTS
No the battery isn't draining over night. Seems to be OK, the only thing that keeps coming on is the compressor for the load leveler, It starts and runs for about 20 seconds and then shuts off. This happens about every 5 to 10 minutes ? What can I do about that ? I'm sure thats not normal. Thanks again for any help.
Dec 18, 2007 at 8:49 AM
MERLIN2021
  • 17,250 POSTS
Check the air ride system for air leaks! Use a spray bottle with soapy water and spray all the parts till you see the bubbles...
Dec 18, 2007 at 12:21 PM
ZIMMIE
  • 7 POSTS
I'll try that. Thanks for all the help.
Dec 18, 2007 at 5:10 PM
MERLIN2021
  • 17,250 POSTS
Sure, that's what were here for!
Dec 18, 2007 at 5:14 PM
